In ear bluetooth earphones recommendation
10 May 2004
Middlesex
Hi Guys,
I have a budget of £70 max.
Usage is split between travelling by train and the gym (so they need to stay in my ears, although I've never really had a problem with this before). I mostly listen to rock based stuff but do listen to electronic (house etc) every now and again.
The SoundMagic E10BT-BK are £50. Are the any good?
Thanks!
The normal e10 were pretty good for a budget. Can't comment on the Bluetooth quality of that model however.
After some research I ended up going for Optoma NE Sport3 (paid around £52).
The e10 wireless and an extra block on the back which was the battery, I think it would have bothered me too much.
Really happy with the sound quality of the Optoma.
I bought Powerbeats 3 I think they were called.
I think there really good. Good sound, don’t loose signal, stay in your ear and the battery lasts for days
