In headset Sidequest beta
20 Apr 2015
Has anyone been running the mobile Sidequest beta in the headset, and have you been able to adjust the settings like screen recording aspect/resolution without connection to an android device or PC?
I think there is only one guy on this forum that could help you. He is always doing the unusual and off the beaten track kind of stuff with his Quest 2.
Hold on and I will ping him.
@drakulton could you help this guy out? :p
I always feel bad that nobody can answer any of your questions and you end up either figuring it out yourself or giving up on it.
Someday mate, I hope to be able to give you a solution and actually help you out!! :)
Thanks @melmac, I did try pinging @drakulton, but to be honest the guy is is an idiot. I came across the cash and carry video, which shows you how to get the experimental app on the headset and all wified up, but then using the app in the headset I was unable to affect any changes.
Essentially I want select 1920x1080 video capture without using sidequest or the batch file connected to the PC. Sidequest mobile linky
It looks like I was a little bit previous as tool functionality isn't working yet, only the in headset game downloads. I think the chrono on my time machine may be a little off wack
last week i tried the in headset sidequest and could download games n stuff but quest settings changes like changing texture resolution i could only do when my quest was connected to my pc.
I think updates will be coming thick and fast as there weren't the extra home rooms that are available now. Settings functionality isn't available yet according to the vid in post#4
