In need of a new case
29 Jan 2013
Hi im currently looking to upgrade my CPU and mobo with the Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle. and am also looking for a new case as my Casecom KM-6988 is making my 7950 look a bit cramped in there.
Im looking for a Case with good cable management and also good airflow around the case. my budget is around between £50-£80 but maybe a bit more as i still need to look at getting an aftermarket cooler for the CPU ( recommendations welcome)
Cheers
I quiet like the look of the Corsair Carbide 300 ( windowed one is outa stock atm tho) the Nzxt and the Bitfenix. im gessing most aftermarket coolers will fit in these cases?
Yep, you should check the CPU cooler clearance of each case and check the size of the CPU cooler (height)
