In need of a quick spec!!
4 Jul 2004
LDN
hi guys, im currently on an opty 170 OC'd to 2.7ghz, 2GB RAM, asrock dual-sata mobo, 8800GTX. tbh its serving my needs but im noticing im not getting the best out of my games with this setup, i know the 8800gtx can perform better.
When i shutdown the computer, just as its about to turn off i hear a loud squeal and it restarts automatically. the squealing remains and i get a black/blank screen. Not sure if its the GFX card (the GTX doesnt squeal at all or under stress in games; its silent); hence i think the mobo is on its way out.
Anyway having been a AMD boy for donkeys years, i think i might as well upgrade and go to intel. I definitely need a CPU and heatsink, RAM and Mobo. Im also contemplating a new case too, but thats not urgent. as for budget, im not sure (but it needs to be as cheap as possible).
Im looking at a q6600 (not sure OEM or retail, anyone?). My main uses will be windows, games and media playback, hd-dvd,blu-ray etc. i think i might as well go quad as opposed to dual as im not playing games all the time, hence it not being a purely games machine.
for RAM im looking at the 2x2gb OCZ PC6400 deal @ £37 at the moment...in a certain way its this deal that is prompting me to upgrade. that seems dirt cheap.
As for mobo, i have no idea..i need something that will overclock well, like get the q6600 to 3.6Ghz easily, and maybe a little further, but i want to use decent(ish) cheap RAM like that above, which should get me to 3.6Ghz no probs. Also need lots of SATA ports, PCI for my X-fi and esata if possible (this is not necessary as i have a esata pci-e card anyway, so if it saves £££'s then i dont need it onboard).
So basically i want something decent with the above requirements; £250-£300 max but the cheaper the better, if i can go lower i would love it.
Now i would love a new case; i got a cheap 20 pound jobby that has served me amazingly well over the years, but case temps are a little too high for me; its also really cramped with cables and hdds clogging it all up. I think i should go for a full tower case, but i need something that is bigger than my current midi case. I do love the look of the coolermaster cosmos rc-1000, but the prices have shot up by the looks of it. oh i would like esata on the case if possible. what cases do you peeps recommend? Something that remains cool with decent space would be perfect.
TIA guys!
With OEM, i think you just get the CPU as opposed to retail you get CPU, termal paste + heatsink/fan. I have no idea why the OEM is slighty more expensive though =/.
the rams good.
motherboard, Asus p5k has plenty of overclocking features
http://www.overclockers.co.uk/showproduct.php?prodid=MB-243-AS
or slighty cheaper, a gigabyte board
http://www.overclockers.co.uk/showproduct.php?prodid=MB-125-GI
so altogether it comes to £249.65 (if you go with the gigabyte board instead)
that leaves you with £0.35 for a case which puts the sonata out the window :p.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-073-AN
Your basket
Product Name Qty Price Line Total
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail £115.99
(£136.29) £115.99
(£136.29)
Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £84.99
(£99.86) £84.99
(£99.86)
Thermalright Ultra-120 Extreme CPU Cooler (Socket AM2/LGA775) £34.99
(£41.11) £34.99
(£41.11)
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) £31.99
(£37.59) £31.99
(£37.59)
Sub Total : £267.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
VAT is being charged at 17.5% VAT : £48.34
Total : £324.55
+ 120mm fan of your choice if you dont have a good one laying about
alternative MB
http://www.overclockers.co.uk/showp...P43 (Socket 775) PCI-Express DDR2 Motherboard to save some money to bring it within budget if you dont need a fan
alternative cpu coolers
tuniq tower
Noctua NH-U12P
thanks for those suggestions, which intel chipset is the one to go for? i need one that will get the q6600 to a decent speed as stated above..what are the differences between intel p35/p43/p45? BTW i have a corsair hx520 PSU already. didnt realise cpu coolers were so expensive these days!
guys im thinking of getting 8gb RAM now that its so cheap...if i were to get 8gb would it affect the overclock of the q6600? Still want a cosmos too :)
