Hi Guys,
I have a system built by OC and yesterday I opened it up and installed a new 1TB HDD.
I was installing windows and during the installation it rebooted in order to complete the setup, however at this point the computer failed to restart.
As the system was failing to reboot, i swapped back to my original HDD and the problem has persisted.
I boot up the computer and i get no display at all...not even post/bios info.
Its as if there is no signal from the DVI on the graphics card. (i have tested the other DVI port, the cable and the monitor and still no luck)
The motherboard (a Sabertooth x58) has power (green light on)
However 2 x motherboard boot lights are staying on. The red LED's are the ones for DRAM and CPU.
At no point did I change or need to touch any of the other parts of the system. cables all appear to be seated correctly.
Does anyone have any suggestions, or know what could be up.
Any help would be appreciated.
