In need of new case fans
4 Apr 2012
England
Hi guys,
I have a Casecom 6788 case (cannot link, competitors and all :() and it has a 120mm Blue LED fan built in at the front. It also has space for a 120/140mm fan on the top; a 120mm fan at the back and space for two 80/92/120mm fans on the side panel. Now, when I bought the case I purchased two 120mm fans that were something like £1.74 each, and used one on the top and one at the back. They both exhaust air, and are what you'd expect for a £1.74 fan (noisy) but do move a fair bit of air.
I'm looking for some new fans to replace them - a new 140mm on for the top and a new 120mm fan for the exhaust on the back. I'd like them to be blue LED, fairly quiet and move a good amount of air. I'm willing to spend up to £10 on each fan.
Also, would it be worth it getting two or even just one fan for the side panel? If I did, should they exhaust air or intake air?
Thanks for any help.
Bit Fenix Spectre Pro fans or Silverstone Air Penetrators, although the later are a bit over budget
