My home broadband is getting upgraded to 5gb next Friday, so I'm looking at taking the first steps into upgrading my current 1gb home setup.
My main PC is mini-itx and has onboard 2.5gb Ethernet, but all other home devices are limited to 1gb and WiFi.
I do have a server which handles all media (Plex), ftp and downloads, so ultimately this needs the most attention.
I've done some research by searching this subreddit and so far I've come up with the following plan...
Get an affordable/cheap unmanaged 2.5G switch with 4 x 2.5G Base-T Ports and 2 x 10G SFP+ ports..
Or maybe get a managed switch which supports aggregation in case I ever upgrade my main PC to something with dual 2.5gb Ethernet?
To upgrade the server, I was thinking of getting an Intel x520-da2
Then lastly, to connect the server to the switch's sfp+ port, this cable. (15 meters)
So to recap, new router and server will connect to the 2 x SFP+ ports and main PC with connect to a single 2.5gb port for now.
Are all the items listed above compatible and are they the correct items for this purpose?
Thanks for reading..
