In need of some advice
How long were these jobs for? If it's less than a month then I probably wouldn't consider putting them down, unless of course you don't have much experience in terms of job history yet.
As SPW says, if you've done them for any length of time and have gained experience from it - it's absolutely worth putting it down. If it hasn't contributed to your experiences then no. Furthermore, if it was a small summer job again I wouldn't have thought it worthwhile.
They lasted for a few months each.
What if you no longer have contact details for an employer, should you still put those jobs on your CV?
If you don't have the details because they've moved, ceased trading, you've lost them or whatever then that doesn't affect that you've worked there so I'd still put down the last information I had for them - it does however make it a bit awkward if your potential employer wants to contact them for some reason. Provided they aren't within your past two or three employers (or directly relevant to the current job you are seeking perhaps) I doubt it'll matter too much as many places will only ask for two referees.
