** IN STOCK NOW ** Corsair HX 650W ATX Modular SLI Compliant Power Supply
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Corsair HX 650W ATX Modular SLI Compliant Power Supply (CMPSU-650HXUK) @ £96.99 inc VAT *** ***
The Corsair Professional HX650W is ideal for performance enthusiasts for whom consistent delivery of rated power output is essential. It delivers continuous rated power at ambient temperatures of up to 50° C. An intelligent fan speed system regulates the ultra-quiet 120mm double ball bearing fan. 105° C rated industrial-grade capacitors provide uncompromised performance and reliability. It’s fully compatible with the ATX12V v2.2 and EPS12V 2.91 standards and backward compatible with ATX12V 2.01 systems.
- Guaranteed to sustain its full rated wattage at an ambient temperature of 50°C
- Up to 85% energy-efficiency under real-world load conditions*
- Single +12V rail design providing up to 52A
- Multi-GPU ready
- Active Power Factor Correction (PFC) with PF value of 0.99
- Supports ATX12V 2.2 and EPS12V 2.91 standards. Backwards compatible with ATX12V 2.01
- Auto switching circuitry for universal AC input from 90-264V
- Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
- Dimensions: 150mm(W) x 86mm(H) x 150mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Only £96.99 inc VAT.
ORDER NOW
Looks a great bit of kit for the money. Was going to buy this from a competitor last week but decided to buy the hx750 from Ocuk instead so i can comfortably go crossfire / sli in the future.
I don't doubt this will be able to comfortably run say two 4890's in crossfire but i wanted the extra room with the 750.
I've just had to return a HX620 - it lasted all of a Week...£27 postage I'm not best pleased with Corsair (my original one lasted ~18 months its replacement 7 days...)
That Be Quiet looks like a non modular version of their range.
The Be Quiet PSU's have been getting very good feedback at the price of that one I'd definatley snap one up.
I've got a Be Quiet and altho of a different range (Dark power pro) Im very happy with it, it's been rock solid for me, very quiet and not had any problems thus far *touch wood*
