*** In Stock Now XFX 5970 ***
Suspended
18 Oct 2002
OcUK HQ
*** *** XFX ATI Radeon HD 5970 2048MB GDDR5 PCI-Express Graphics Card @ £538.99 inc VAT *** ***
The fastest graphics card on the planet, the ATI Radeon HD 5970 delivers an unrivaled HD gaming experience so you can play the latest, most demanding HD titles like never before. Engineered for speed, this next-generation powerhouse delivers unprecedented performance straight out of the box. Unlocked, this graphics card has massive headroom so you can take control and push your hardware to its full potential! Expand your visual real estate across up to three displays and get lost in the action with ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. Among the first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals with explosive performance so you can dominate your gaming competition.
- Core Clock: 725MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 256GB/s
- Processing Cores: 3200
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Only £538.99 inc VAT.
ORDER NOW
What is it with ati warranties, far as im aware in the us the xfx warranty is around 5 years+, the vtx 5970 only has a warranty for a year. Half a grand and a years warranty. :eek:
looks like its still better just to get 2x 5850's or 2x 5870's if you can afford it
plus they arent as long as that beast so should fit in more cases
Say you wanted a 4 card crossfire setup, how would you even power them? I read they use 300w on full load?
Wouldn't you need 2 PSUs or something? Especially if you're watercooling them?
Also is it possible to overclock these at all? With 3200 cores, I'm guessing even a 1mhz increase would make a big difference. :P
Even if I won a £45 million jackpot lottery, I think I would feel guilty on spending £500 on a gpu.
But, unless I win a £45 million jackpot I will never know. :(
If I won that, I'd build the fastest most silent intercooled water cooled monster ever concieved. :D
It'd need dual CPUs though, definately....
