Hey guys I have suddenly run into a problem with my build.
I got an Dark power pro 750w.
I tested cpu+ram+graphics outside the case, got pc to post and enter bios.
So i started putting it into my case antec 902. Still working when i had all the front connections connected etc..
Now I tried to connect the case fans to the psu. When i had all 4 connected, i tried switiching the pc on again. All that happened was the psu/cpu fans started moving (not spinning), and there was one CLICK coming from the psu, and it would turn off again (all taking less than a second). So now i connected only two fans (both to the same molex cable from the PSU) and it worked, then i tried all four again (2 on a molex cable each). Still wouldnt work. I all tried them independently and they worked. Then suddenly with just one connected i got the same problem again, so i disconnected it again.
Now I tried starting pc again with no case fans connected at all.
Just the graphics card, the cpu and the ram.
But still all I get is a click noise from the PSU, a short movement of the cpu/psu fans, and then it turns off. When I then try the power switch, nothing happens whatsoever. I turn the psu off, unplug, plug it back in and try again(waiting at least 5 minutes before reconnecting). Same thing each time I try?
Any suggestions?
Any suggestions?
