What about a PSU?
Not only that try looking up the Tuniq cooler (sorry forget the full name) i hear it's a good cooler at keeping temps down plus i think it's cheaper.
The OCUK 24" monitor will save you some pounds so check that out as well.
No need for a sound card, the asus one is very good.
I would also get the Asus P5K-E WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
drop the fan controller and just buy some Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
