Hi there,
I am currently having my small 2 bedroom London flat refurbished and am taking every opportunity I can to spec it to my own geeky taste. I have a pillar (approx 30cmx45cm) in the middle of my open plan kitchen/lounge. It's only about 40m² so not a huge space. Whilst the pillar is exposed (before dry wall is built around it), I'd like to put in 2 discrete speakers, one either side (pointing away from each other, out from the center of the pillar - 1 into the lounge area, 1 into the kitchen). The pillar has a mains power circuit which is due to be wired to a dual socket once the dry wall is in so I figure I can use that to power any amplification/audio receivers.
That's about as far as I got . My budget is probably up to £500 for a pair of in-wall speakers, hidden amplifier and some sort of wall plate to adjust volume/accept inputs. I wouldn't call myself an audiophile and, given I won't be adding a subwoofer to this setup, would appreciate a pair of speakers that aren't too bass shy.
Can anyone recommend me a pain-free setup that I can install myself? As you might have guessed, I'm hardly the expert with these things so an average install that is painfree would be preferable to ultra quality audio. One of my main considerations is the ability to play audio from mobile devices. The ability to hide a AirPlay or bluetooth receiver would be ideal as well as a wall mounted faceplate with an aux in port as well as a amp volume knob? Am I asking too much?
Cheers for any advice!
