- 11 Dec 2005
- Cheshire
Our friends at Vortez have reviewed the super slick in-win 904 mid tower chassis and awarded it both the silver and creative award!
read the full review HERE
In-Win 904 Mid Tower Case - Silver @ £149.99 inc VAT
The In Win 904 Mid Tower Case brings In Wins award winning innovations to another level, with the stylish hairline texture surface design and the ease of use of the case, and great cooling capabilities, with the ability to house any size GPU and cable management that will keep your components looking clean and tidy, and how else would you like to show your awesome gear off with the toughened glass side panel. This is an ultra premium, Unibody design at a perfect price point.
Features:-
- Extreme simplicity design, Elegant back panel, Stylish hairline texture surface design
- Easy Component Installation
- Spacious Cable Management
- Excellent Thermal Solution
Specification:-
- Case Size: Mid Tower Chassis
- Material: 2mm/4mm Aluminum, 5mm Tempered Glass
- M/B Form Factor: ATX / Micro-ATX
- Power Supply: ATX 12V, PSII and EPS Up to 180mm, (with extra space approximately 20mm)
- I/O Expansion Slot: PCI-E / PCI / AGP Slot x 8
External Drive Bay:
- 5.25 “ x 1
Internal Drive Bay:
- 3.5” / 2.5” SATA HDD EZ-Swap Module x 3
- 2.5” x 2
I/O Port
- USB3.0 x 4
- HD Audio
Thermal Solution:-
- Supports - 90mm Rear Fan x 1
- 140mm Bottom Fan x 1
- 120/140mm Liquid Cooling
Only £149.99 inc VAT.
ORDER NOW
in win, the formidable innovators are back with another adventurous computer case which breaks the mould. while it may not tick all the boxes for some due to it fitting into a niche, 904 is very intriguing. it oozes quality and works great with 120/140mm aio coolers. - vortez
Features:-
Specification:-
External Drive Bay:
- 5.25 “ x 1
Internal Drive Bay:
- 2.5” x 2
I/O Port
- USB3.0 x 4
- HD Audio
Thermal Solution:-
ORDER NOW
