In-Win BM648 Problem
2 Oct 2004
Just got this case and it was my understanding this case could house a 5.25" drive and a 3.5" hard drive, I've managed to get both installed but the PSU only has 1 sata connector so I obviously cant have both installed, am I being thick or were you meant to purchase a converter to have both installed?
Thanks in advance.
You will need a molex to sata converter, do a google search and you will find that you can get one for under 2 pounds + postage. Also check to see if one was not included with your MB.
OMG I can't believe this, the mains cable isn't a normal one, like a 2 pin one so obviously cant plug it in, is this normal :(?
Yeah, its 2 pin plug, guess I'll have to take it all apart again and RMA it.
EDIT: I'll have another look in the box n stuff.
I just have 1 mains lead, one end the 3 pin one which goes in the back of the PSU but the plug which I plug into the mains is a 2 pin one.
I don't remember having that issue during my build, I'll check when I get in.
I did get a two pronged power lead though, mine was also from ocuk.
Oh, well I can't obviously connect a 2 pin plug in the mains and it hasn't come with a adapter of any sorts.
