In-Win D-Frame at OcUK!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Get these, very limited edition and very unique.
In-Win D-Frame Limited Edition Open Frame Chassis - Red @ £329.99 inc VAT
Continuing the frame concept and the innovative Open-Frame structure design of X-Frame and H-Frame, In Win introduces the third generation concept chassis, the D-Frame. The perfect combination of craftsmanship and technology. The D-Frame is handcrafted with 100% fine alunumium and demonstrates In-Wins pursuit of absolute precision.
A very unique and interesting chassis from In-Win has arrived, made from Aluminium piping. The open air design provides excellent cooling, the frame is hand crafted and precisely welded for better protection. The PSU holder design is adjustable for better flexibility. The chassis can support graphics cards up to 33cm in length. Spacious cable management area. The chassis has a shock proof stand for excellent shock reduction, which can help extend the life of your components. The chassis has the ability to install four 120mm fans, which combined with the air design should give more than enough cooling for any high end system. The motherboard plate is hand crafted with sand casting techniques to give thge rugged-edge look and feel.
- Open Air Chassis
- Material: Aluminium Pipe
- 1 x 5.25" External Bay
- 3 x 3.5" and 2 x 2.5" Internal Bays
- Revolutionary 90 degree motherboard mounting for easy access high expansibility
- Tempered glass side panel
- Motherboard Support: ATX & MicroATX
- I/O Ports: 2 x USB3.0 and HD Audio
- Expansion Slots: 8
- Dimensions: 482 x 305 x 668mm
Only £329.99 inc VAT.
ORDER NOW
In-Win D-Frame Limited Edition Open Frame Chassis - Orange @ £329.99 inc VAT
- Open Air Chassis
ORDER NOW
