INACCESSIBLE_BOOT_DEVICE
20 Mar 2004
Got a wierd little problem with my Dell laptop, the hard drive died, so I replaced it and attempted to reinstall, however near the beginning of the win2k professional setup, I get a blue screen with the message.
I've tried another hard drive but get the same message at the same spot, only other thing Ive tried is a memtest, which it passed.
Any ideas?
Did you format the drive(s) and install windows from scratch?
That message is usually when windows does not have the correct drivers for the hard disk controller installed (i.e. taking a disk from one machine and putting it in a machine with a different controller will cause this blue screen)
Have you checked/changed the BIOS configuration so that it matches the new disk?
Occasionally the values are fixed at the factory to match the geomatary of the disk and need to be changed.
Its a new drive.
I've tried doing it completly blank, I've also tried partitioning it and formating on another machine then sticking it in.
I checked the bios, but there's no kind of option to change the hard drive, no auto detect, settings etc.
Is there a BIOS update for the Laptop?
Have you got another OS disk that you can try?
Do you have the ability to download and create the manufacturer's hard disk diagnostic utility?
