Hey up all,
I just ran CPU-Z in Windows XP 32bit on a Multicore processor PC and noticed it said 1 Core and 1 Thread at the bottom.
The CPU is a Intel Core 2 Duo E6600 so it should be showing 2 Cores surely?
Did some poking around on the net and checked the 'Computer' configuration in Device Manager and its listed as an Advanced Configuration and Power Interface (ACPI) PC.
Am I right in thinking it should be showing as a ACPI Multiprocessor PC or MPS Multiprocessor PC?
Task Manager is also only showing 1 CPU Usage History and not 2.
Does this mean the wrong HAL (Hardware Abstraction Layer) has been implemented into the XP install?
Ive read that you shouldnt/cant change the ACPI in Device Manager without running into problems and its best to do a fresh install of XP.
My question is this thou, even thou XP and indeed CPU-Z are reporting the CPU as only having 1 core when there is infact 2 as per the BIOS settings, does this mean XP is only utilising 1 core and not 2?
AKA, is this computers CPU performance in effect halved as only 1 core is being used?
Thanks for reading and any help would be much appreciated.
