Have just been looking at some gpu reviews as i am currently on the hunt for a new card (just posted a thread) and just noticed a MAJOR mistake with the testing at OC3D (TTL). He has changed test setup yet his results are the same!!!
How can an i7 3960x @ 4.5ghz with 16gb dominator platinum on a rampage 4 get the EXACT same results as an i7 950 @ 4ghz 6gb mushkin on a G1 assassin????
Check out the MSI GTX 560 results, original review scores are included with the new GTX650ti results:
Old review test setup: http://www.overclock3d.net/reviews/gpu_displays/msi_gtx560ti_448_core_review/3
New review test setup: http://www.overclock3d.net/reviews/gpu_displays/nvidia_gtx650ti_boost_review/3
Now check out Batman results for each review: they are exactly the same. I imagine the rest of the results are the same too when you do comparisons...
How can something like this be trusted? It's very misleading....and obvious cutting corners.
