Hi guys.
THe water system in our house is as follows:
Combi boiler so mains pressure to all hot water outlets plus cold water in kitchen.
Bathroom cold water systems are fed from the loft cold water tank.
SO, in our bath & shower, we get more hot water pressure than cold water pressure, which makes it fairly difficult to get the water temp right for us. ( i also need to change the washer on the hot water bath tap). The previous home ownders also had 15mm piping going to the bath instead of the 22mm that i would have fitted.
Anyway, i was considering, is there a fairly inexpensive way to increase the pressure coming from the cold tank to the bathroom, not too much, but just enough to get it slightly more than mains pressure. Some sort of low pressure pump i would imagine.
Thanks guys,
Mal
Thanks guys,
Mal
