Increasing Wifi coverage
12 Apr 2010
Balsall Common
My current home setup is a homehub 5 in the centre of the house, providing wifi coverage throughout the house. We then have ethernet cables running off this to a home network covering the lounge, kitchen and bedrooms.
We have a final ethernet cable that runs out through the garage then outside into a home office/cinema room we have installed in our garden. This gets us wired connection via a switch to my mac, xbox, skyQ etc in the office but no wifi coverage as its too far from the homehub 5. What would I need to connect off that switch via an ethernet cable create wifi coverage in there? Is it a further router? Access point?
Access point?
You got it.
You can buy an access point, or set up almost any integrated unit (modem/router/AP) to be one.
The unit you need depends on the throughput required down there, and the wifi range. If it's short range to just a few regular devices you need something a lot less special than transferring masses of data, for example.
