** INCREDIBLE BENQ 32" MONITOR DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Two incredible deals from BenQ making us the cheapest in the UK by miles on price. :)
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £359.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- VA (AMVA+) LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr (On-Site with BenQ - 0207 216 0039)
Was [£379.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
BenQ BL3201PT 32" 4k 60Hz Professional Widescreen LED Monitor - Black @ £599.99 inc VAT
The BL3201PT, a stunning 32”W display built with IPS technology and the latest 4K2K ultra-high-definition resolution, as a part of its continued effort to support the visual-intensive work required in the fields of CAD/CAM, animation, video editing and graphics arts. So professionals with a meticulous eye for detail can work with perfect precision and achieve high productivity.
Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL3201PT boasts a 32”W 4K2K display built with BenQ’s advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ’s BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
For clearly distinguished details in complicated object wireframes, switch on the CAD/CAM Mode to alter the monitor’s color and contrast settings to view highly detailed graphic information without ever missing a line again.
SolidWorks Certification Being a Solidworks Solution partner translates to display excellence certified to be of professional standard for CAD/CAM software users.
Professional animators work to breath life into moving art, making even the tiniest detail paramount to delivering lively creations. To answer the visual demands of the most sophisticated animators, BenQ BL Series monitors give you uncompromising accuracy consistency for displaying every shade of colors through a wide range of optimized image calibration settings, including the brightness-enhancing Animation Mode. There is also a multitude of viewing features incorporated into the monitors to simultaneously display all the information needed for making color adjustments. So no detail can escape the eyes of its creator!
To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork – without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly.
Color accuracy and a clear line of view are of utmost importance for anyone working in the field of professional video editing. BenQ BL Series offers a wonderful range of 100% sRGB monitor with a resolution of QHD and 4K2K UHD to give you crisp and clear viewing quality accompanied by true, lifelike colors. The large viewing space combined with optimal viewing prevision give video editors full access to all the editing tools, applications and images they need to work with. So they can perform every task with maximized efficiency.
A high-quality monitor with high resolution, high color accuracy and fidelity and a wide range of high-speed connectivity options is what makes a perfect companion for professionals in the graphic arts industry, including graphic designers, retouchers and photographers. Featuring the highest resolution at 3840x2160 4K2K with 100% sRGB and BenQ’s advanced IPS technology, the BL Series showcases consistent, reliable color results with every detail precisely rendered for a brilliant viewing experience from virtually every perspective. A variety of connectivity and view options also enables users to work with multiple devices and perform complex multi-tasking work with ease.
Designed for professional designers accustomed to work with a square monitor, this feature allows them to work with nearly two 19” displays by dividing a 32” BL Series monitor screen into two 4:3 or 5:4 viewing areas – which can be further resized from 19”S to 30”W in size using the Display Mode feature. For enhanced convenience and productivity, the PIP/PBP feature allows you to compare two or more pictures as well as display drawings from two PCs simultaneously for a more efficient work discussion.
The Display Pilot software is a total solution package for designers seeking to customize their display. You can assign specific color modes to frequently used software applications on your computer with Application Tuning, and Display Pilot software will automatically apply the preset color mode to the matching software application in use. Other features that can also be accessed through Display Pilot include Auto Pivot, Desktop Partition, PIP/PBP and other OSD settings such as brightness adjustments.
Auto Pivot detects the movement of the monitor and dynamically rotates the contents displayed for flexible landscape or vertical viewing without utilizing Windows or graphic card settings. The BL Series are newly upgraded with the incorporation of BenQ’s proprietary Flicker-free Technology to eliminate backlight flickering at all brightness levels and effectively reduce eye fatigue. Conventional LCD screens flickers 200 times per second. The flickers may not be detectable by your eyes but they can certainly feel the flickering. So it is important to relieve your eyes from the stress caused by a flickering screen – and keep them nice and fresh when you are working on new designs.
Features:-
- 32”W Large Screen 3840x2160 UHD Resolution
- 100% sRGB Color Space
- Display Pilot Software
- OSD Remote Access
- CAD/CAM Mode and Animation Mode for Precision Design
Specification:
- Display Screen Size: 32"
- Aspect ratio: 16:9
- Panel Type: IPS
- Brightness: 350cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 20,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 4ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 178 ° / 178 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Mini-DisplayPort (60Hz), 1x DVI-DL
- USB Hub: Yes (USB3.0)
- Speakers: Yes (2x 5W Stereo)
- VESA: 100x100mm
- Height adjust, pivot, swivel stand
Was [£689.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
A pair of two incredible monitors at very aggressive pricing. :)
That is a superb price for the 3201PT! I might have to return mine (bought from elsewhere) to get it at this price!!
What they aren't are free sync / G-sync.
What they are, are superb quality, unlike many of the other 4k panels out there!
this is the best looking 4k monitor ive seen, id have kept mine if it didnt give me huge eye strain (due to the small text etc which im very sensitive to)
Interesting feedback chaps, thank you. Up until now I'd been considering the Philips but I wonder if this might be a better option for me instead.
This review seems to suggest 70cm was not a problem for the reviewer's eyes (I appreciate everyone is different). I'd be interested to hear what kind of distance those of you who have (tried) this monitor sit (sat) from it. I'm sitting ~84cm from my DELL U2713HM and can easily cope with smaller text, thanks to LASIK surgery back several years back. From the specs it looks like the BENQ pixel size is 80% that of the DELL.
