I did have an Abit Fatal1ty motherboard, and there was a bit of annoying static.
I've just moved to a Asus A8N32 board, and the static is worse, it drives me up the wall.
I usually use headphones, decent ones too
For some reason I don't get the static when the CPU is under load - if I run Orthos for example there's no static at all. If I don't have the CPU under load the static is awful.
Can anyone suggest either a fix for it, or, if a decent soundcard will prevent it?
