- 12 Aug 2015
Someone must know the answer to this
One day i moved the case slightly and the machine wouldn't boot...red mem light on.
Eventually after a lot of messing about i found that the psu was dead , 1 stick of ram dead and the cpu gone.
Time To upgrade , i got a new Asus p8z77-ws Booard , 32GB Ram and a 3770k CPU and a Corsair Rm 850 PSU,
loaded it all into the Silverstone case and after leak testing fired it all up.
One thing i noticed straight away was that the thing was sluggish , it took a long time to boot , you had to mess about restarting it but eventually it fired up , water temps were always acceptable ,but something wasn't right.
In the end i took it all apart and cleaned up the gpu, the 590 was almost 4 yeas old and i noticed some of the pads had melted and crublemd so i took it all aprt and cleaned it all up.
While all this was happening i found a cheap Corsair 900D on Ebay so snapped it up.
Rebuilt the machine back into the new case, added in 2 extra radiators as there was room to handle it.
Added in a lamptron Fan Controller to power the fans
Fired it up and got the no VGA Beeps , nothing i could do would fix it , so i threw in the towel and bought a brand new GTX 980ti from Overclockers (block fitted as supplied)
Fitted the card , fired up...Bios still very slow , gets stuck on the q-code B2 for a long time , it will boot eventually but you have time to RTFM a few times whilst it does but it is still sluggish
the motherboard has on board gpu so i unbolted the gpu , pulled it out slightly so it wasn't connected , removed the power from the Card and fired up the system....
It shot throught the post , and booted withing a few seconds.
I card was brand new and i don't think both cards would be out so i'm looking at the PSU either being faulty or just not up to the job
System specs
Case Corsair 900D
MB P8Z77-WS (Latest Bios v 3505)
CPU I7-3770K
GFX Nvidia GTX 980 TI
1 Bluray Drive
1 Samsung SSD
2 x 4TB Seagates HD
1 x front sata drive caddy (2.5 / 3.5)
1 x lamptron Fan Controller
1 x 480 (4 x 120 fans)
1 x 240 (2 x 120 fans)
1 x 480 (8 x 120 fans 4 pull , 4 push)
1 x 140 Fan (Exhaust)
2 x 120 (front pull)
Yeah it is probably fan overkill but i consider myself slightly Autistic and if i have a slot free i need to fill it
all this is powered by a Corsair RM850
Question is is it up to the job?
***UPDATE****
I disconnected all the fans and HD's etc except the SSD.....Same Thing
I pulled out the 980 and replaced it with a passive cooled brand new 210. Same thing. Post is VERY slow.
I put the 210 in the 2nd x16 slot....Same thing. Post is VERY slow.
I've removed the cpu and checked for bent pins , can't see any bent pins.
System specs
Case Corsair 900D
CPU I7-3770K
1 Bluray Drive
1 Samsung SSD
2 x 4TB Seagates HD
***UPDATE****
