Having a nightmare of a time deciding on which case to get.
The choices are:-
Antec P193 v3
Antec P280
Antec P183 V3
Fractal Designs Define XL USB 3.0 Titanium Grey
The stuff thats going in it:-
i7-930 Processor @ 3.5Ghz
GA-X58A-UD3R Rev2.0
Geil 12GB DDR3 1333 CL9 T/C RAM
GTX 560 Ti 880MHz 1GB Twin Frozr II/OC
Ocz 750W ZT Series Fully-Modular Power Supply
6 HDDs
and one day a couple of SSDs
Current cooler is an Antec Kuhler Shelf, but this is probably going to be replaced with either the Corsair H80 or the H100 depending on the case.
I has to be a sleek case, some thing a bit less "show off" and a bit more "grown up"
I would appreciate your input and any other suggestions you have, Pros & Cons of each etc.
Cheers
The choices are:-
Antec P193 v3
Antec P280
Antec P183 V3
GA-X58A-UD3R Rev2.0
6 HDDs
Cheers
