Indentification of my AMD CPU??
10 Nov 2007
Hi All
I have a problem with my MSI K8N Neo Plat MB - see other posting. If I cant get if fixed I will need some advice on replacing it with an alternative.
When my Brother and I put this pc together we originally tried an Abit 3rd Eye MB that would not work for some reason - I was told that it was becuase the AMD 64 CPU that I was using was a particular type.
Is there a way of identifying it from the following info stamped on the CPU
AMD Athlon 64
ADA300DIK4BI
CBBHD d450APBW
116397L 406160
Also I' be gratefull for any / all advice on an alternative MB (AGP slot preferred)
Thanks
Yep. Btw, a BIOS update on the AV8 would've solved that issue. Years ago i had a whole load of about 11 brand spanking new AV8s for a job and all the cpus were brand spanking new to England Winchester core 3200+s and nothing worked :D Had to go around with a 3500+ Newcastle and flash em all to the newer BIOS and they worked fine since.
