InDesign Help! Bullet Points...
20 Sep 2009
Portsmouth
Worth a shot! Someone here must know...!
Basically, I have a paragraph style set up that includes bullet points.
That all works fine, but for the life of me I can't work out how to automatically indent the next line after a bullet point so that it lines up with above.
I can press tab... But if I do that then when I change the size of the text box the formatting messes up.
Hope the screenshot helps..!
Right... There's an invisible character that does this.
After the bullet point and the space type ctrl + \
After that they should run around to that point. Well it should be right, it's  + \ on a Mac anyway so should be ctrl + \ on PC.
I meant new bullet, not new line. When I'm doing it I tend to do the bullet the space and this character then copy them all and just paste them all in, I think in Quark I had a thinger set up that was a 'text bullet' that included the space and invisible character. I can't for the life of me remember what the character's called though, it does have a name.
