11 May 2008 at 21:30 #1 BobBrainy BobBrainy Associate Joined 23 Mar 2007 Posts 321 hey, I'm using indesign and I want to give my project a 3mm bleed all the way around, where is the option to set bleed within indesign? I know you can set it on a new document but can you do it on an already opened one? thanks.
11 May 2008 at 21:35 #2 swinnie swinnie Soldato Joined 30 Apr 2007 Posts 3,095 Location Kent BobBrainy said: hey, I'm using indesign and I want to give my project a 3mm bleed all the way around, where is the option to set bleed within indesign? I know you can set it on a new document but can you do it on an already opened one? thanks. Click to expand... I haven't used InDesign, but what about Page Properties/Setup?
