Looking to replace the indicators on my hornet as they look huge, plus one of the rear ones is taped together from previous owner so a good time to change.
There are lots of aftermarket indicators , bulbs and LEDs
I know the LEDs ones need a relay but interms of safety and being seen are the LEDs indicators any good in day light ? I've been reading conflicting info on the Internet.
Some say LEDs have a very directional view unlike bulbs , night time they are spot on but in daytime they are not very good.
Also what halogens if a car hits you and they says I couldn't see your indicating as they are so small?
So my options are:
1. Stay with stock (put up with ugly but be seen, be safe)
2. Fit LED indicators (look amazing but maybe not as bright as bulbs?)
3. Fit smaller bulb indicators ( best of both worlds sort of!)
What are your thoughts ?
So my options are:
. R&G do resistors pretty cheap for theirs which work nicely and easy to install.
