- 24 Feb 2011
Just been checking temps..
Core 0 55c
Core 1 63c
Core 2 52c
Core 3 63c
Got a 11 degree difference between 2/3 ? (this is using CPU ID hardware monitor)
Realtemp is giving me 56/63/52/62 So very similar results to the one above.
Can't seen the Thermal grease been a problem, i put it dead center tigthened all screws fully so even pressure is on them. (Exactly how i did it last time) although last time i had a bit too much on, but the tim pattern was equal.
any suggestions? I don't really fancy spreading the tim. Is a 10 degree difference between cores usual?
(been running prime 95 for the last hour or so)
Core 0 55c
Core 1 63c
Core 2 52c
Core 3 63c
