The right induction kit in the right car can add performance and sound better.
The ianm one I had on my e36 supposedly added to the performance.
What car do you have?
Sounded absolutely as good as it gets for a crappy low-revving 4pot, don't think it did the engine as much harm as the way I drove it!
Just recently picked up a Focus 1.8 Zetec
) which did have an affect on the cars fuel economy and dropped it by around 3-4mpg. There was no noticeable difference in performance though which was odd. Gone with a Green replacement panel filter on the Megane.It's definitely the right way to go, but it can end up being expensive and time-consuming for what amounts to something of a placebo effect.I'm sure theres a good mod to do to the MK1 focus whiich involves fitting the air intake from the ST170.
Fit the ST170 snorkel and airbox if you want better induction. OEM is quite often best![]()
no in that case
What age focus is it though ?
*edit* here we go
http://passionford.com/forum/ford-focus-and-focus-rs/308582-ford-focus-1-8-zetec-petrol.html
