Inexpensive rad fans
26 Jan 2005
In........cognito
Hi,
I'm looking for some 120mm fans for rads and was looking to get some opinion from you chaps. :)
The radiator I'll be using will be a Phobya Xtreme QUAD 480 so the prerequisites are that it must suit that radiator's FPI, be <£10 each and have 3 pin connectors so that I can connect them straight to my mobo for control(so max fan speed needs to be 1500rpm+).
So far I've been looking at the Scythe Slip Streams (preferred so far), Noiseblocker BlackSilent Fan XL2 and the Alpenföhn 120mm Wing Boost Pure Plus PWM.
Any help much appreciated. Thanks! :)
Yate loon 1350rpm. Cheap as you like, can be had for a few quid each and very popular in WC circles.
