Infinity 2 question
28 Sep 2008
Britain
Just ordered this as got quite a good deal through the post (it's recently been put in at the exchange).
Will my Draytek Vigor 2820n be ok with this?
Ahh, that should be fine to be fair. However, in essence, we're saying that I might be better off with the default home hub until I upgrade my Draytek?
It'll depend on:-
  • How much speed you actually lose with the Draytek. Depending on your distance from the cabinet it might not be enough to worry about.
  • If you use any of the Draytek's more advanced features.
  • If the Draytek's wireless is up to the job.
