Inflatable sausages?!
Caporegime
21 Oct 2002
Here
Taken from fridge in Tesco and put in my fridge at home.
Why have they turned into a balloon?
well.. i would say its due to a gas build up inside.. and if they r doing that then i wouldnt eat them
I did wonder if they were going off causing the gas. 4 days to go before they are out of date though.
I came here looking to see some inflatable sausages and all i got was a plastic bag that had inflated. NOT sausages, YOU LIED TO ME.
Open them, smell then and if they don't smell rancid, eat them.
Do not waste good sausages. If you're going to bin them, send them to me and I'll eat them instead.
Someone took them out of the fridge at Tesco then decided at the beer aisle they didn't want them and dumped them next to the cans of Stella. They stayed there for 8 hours before a shelf stacker noticed and put them back in the meat section. ;)
Looks like they are off to me. Get them changed.
Have a look at this - exactly the same:
http://www.eatwell.gov.uk/asksam/keepingfoodsafe/asksamstoringpreparing/#A220117
I was intending to cook a packet of sausages today but the pack was inflated. So even though they were still well within the 'Use by' date I threw them away. Was I right?
When bacteria grow on food they sometimes produce gases, which can make packaging swell. This is the most likely explanation of what happened to your pack of sausages. Because the sausages were going to be cooked, these bacteria might not have made you ill. But throwing away the food was the safest option.
Raw sausages often carry bacteria and the most likely cause of the pack's swelling is that it got warm, which would have allowed the bacteria to multiply and start releasing gases. This could happen if the sausages were out of the fridge for a while, for example, when you were bringing the shopping home. You should always try to put food in the fridge as quickly as possible, especially in warm weather, and avoid leaving food in a warm car boot.
Food might also get too warm if your fridge isn't cool enough. Using a fridge thermometer, check that the coldest part of your fridge is between 0°C and 5°C (32°F and 41°F). If your fridge has an internal freezer compartment that is iced up, this could mean that the fridge will struggle to maintain its temperature.
This.
