Info....Disable GeForce GTX 580 Power Throttling using GPU-Z
22 Sep 2009
............As an obligatory caution, be sure you know what you're doing.
TechPowerUp is not responsible for any damage caused to your hardware by
disabling that mechanism. Running the graphics card outside of its power
specifications may result in damage to the card or motherboard. We have a
test build of GPU-Z (which otherwise carries the same-exact feature-set of
GPU-Z 0.4.8). We also ran a power consumption test on our GeForce GTX 580
card demonstrating how disabling that logic affects power consumption.
http://www.techpowerup.com/134460/Disable-GeForce-GTX-580-Power-Throttling-using-GPU-Z.html
