info on ubuntu boot
3 Dec 2002
Groovin' @ the disco
Hi
I installed cli only ubuntu server, and there's a little bit of system summary that tells the user the number of users, hdd space, ip address.. whats the program called? as I want that on my pi. :)
Thanks
nothing that posh.. this is what it looks like
it's from the update-motd.d scripts
Code:
lee@sakura:/etc/update-motd.d$ ls -l
total 28
-rwxr-xr-x 1 root root 1220 Jul 14  2011 00-header
-rwxr-xr-x 1 root root 1358 Jul 14  2011 10-help-text
-rwxr-xr-x 1 root root  149 Jan 25  2011 90-updates-available
-rwxr-xr-x 1 root root  129 Jul  9  2011 91-release-upgrade
-rwxr-xr-x 1 root root  142 Jan 25  2011 98-fsck-at-reboot
-rwxr-xr-x 1 root root  144 Jan 25  2011 98-reboot-required
-rwxr-xr-x 1 root root 1158 Jul  8  2011 99-footer
Code:
total 28
Thanks...
How do I get just the system information bit to run by itself?
found it.
sudo apt-get install landscape-client
landscape-sysinfo
Code:
lee@sakura:~$ landscape-sysinfo
  System load:    6.63                Processes:           195
  Usage of /home: 93.9% of 904.10GB   Users logged in:     1
  Memory usage:   37%                 IP address for eth1: 192.168.0.100
  Swap usage:     0%
  => /home is using 93.9% of 904.10GB
  Graph this data and manage this system at https://landscape.canonical.com/
found it.
landscape-sysinfo
Code:
  Swap usage:     0%
Thank you so much,
I tired add in the repos in to my pi's resources and it doesn't work. Checked the FAQ on the site and it says that it doesn't support Debain.
