Ininity live info
27 Jan 2005
Letchworth Herts uk
Hi All ..My Telephone Exchange is due to go live on the 31st of March..Anyway i emailed B.T Support on there website & i got these replies back i,m confused as to whether i,m going to be able to order Infinity on the 31st March or what ?
Hello Mr ******
Postcode sg6 4pr is connected to cab 9 and you should be able to order infinity on the 31st.
SG64PR {SMLH}{P9} 0 100% 7.2 7b Yes FTTC
Hi Mr ****** this is the latest (Dec) data on your postcode:
The good news is that your postcode is scheduled for upgrade to FTTC but it could take up till end of june to be finalised
Also the old cab is 9 (should have it painted on it) close to it should be the new FTTC green cab so you can check it out
SMLH LETCHWORTH SG64PR {SMLH}{P9} 0 100% 7.2 7b Yes FTTC
if you want infinity, call up place your order if your line isnt enabled yet then they will put you on adsl and upgrade you as soon as its enabled.
It's clear you left so long ago, since you've forgotten how to use punctuation.
Perhaps he is so old, he left before it was taught, perhaps he is so old he fails to recall that he has posted threads in the past.
It is quite good, I am contemplating a house move, which would force me into an infinity area, and all of jamjars questions, although spread across a million threads are reasonably beneficial.
I don't understand this thread is is more of a statement, that could have been included in the BT infinity thread.
Please, could you make use of your existing threads instead of making new ones? Anybody looking for information will get confused with so many threads, whereas if you kept everything in one thread, it would be much easier to find.
Think about it like this: if you were writing a new paragraph, would you start a whole new page? No. You would miss a line and continue writing, so do the same thing on here and add a new post to an existing thread.
Thank you.
Thank you.
ok dude i is tinkin bout tings you is da dude of da place chow dude !
I is not old dude i is da bad ass Daddy of da joint ! chow bro :)
