- 31 Oct 2002
Wow the thing is large and heavy! First thing I noticed when I lifted out of the box was how heavy it was. It's also very long, sticks out of the front of my desk actually.
I got the black version, and replaced the stock fans with some blue Akasa ones, so get a nice blue glow front and back when in the dark.
I have only 2 complaints about this case...
1) The front door is very badly fitted. When on level ground, it swings inwards, meaning that it's a real pain when loading and unloading DVDs as you actually have to hold the door with one hand to stop it banging against the DVD tray. Also it rattles when the case is moved, and will open with the slightest brush, it lets down the case generally.
2) The fixing mechanism for the PCI cards is very badly designed - in order to get the PCI cards in I had to go dangerously close to the motherboard with the metal at the bottom which could have caused damage - good idea but not enough room provided to fit the cards easily and safely.
Overall though I am very happy with the case. Will post some pics later if I remember!
