oki doki
got my 6300 this morning and plugged it straight in
didnt even bother putting the motherboard inside the case and just testbedded it
oki i had to get some other ddr2 as my ocz wouldnt work unless the votlages were pumped up +0.3
once raised i got the pc2-8000 up and running
set the multiplier to 2.0 raised the cpu freq to 500, upped the voltages on the fsb and cpu and locked the pci-e
disabled all the other throttle crap and bingo
7x 500 = 3.5 ghz at 1.375volts using stock cooling at 42C
got it up to 3.6 ghz before it locked up
not a bad board considering it is b grade from OCuk pmsl
waiting for my actic freezer 7 then i will play a bit more
