Inline frames, please help!
18 Oct 2002
Bristol
Hi we are trying to make a site, we dont know much about HTML e.t.c but we are using inline frames which seem to be pretty simple to use
www.clio16valver.co.uk
Now its all fine and dandy, until you create a page for the inline frame that is too long to scroll bars appear, click the little white star on the nav bar. The page appears and the scroll bars do too.
The vertical scroll bar is fine we can all understand why that is there, however the horizontal one is useless and i want rid of it, it happens to ALL pages in the inline frame as soon as they become to long for it, regardless of the width of the page.
Any help would be great.
get rid of the frame. let people scroll conventionally.
also I don't recommend that you use the logo and menu as one graphic and then use a click map.
I agree. Kill the frame and just put the copyright notice at the bottom of the page. IFRAMEs are generally bad for accessibility and as you've found, give you weird scrolling problems :)
There is a way, it is a little complicated, I coded it in javascript about a year ago with help from people here.
Better to dump the iframe...
