Hello. I have a problem with the graphics card from Inno3D ichill gtx 1070-3X The problem is as follows when the computer is turned on, the fans and backlight normally turn on, but the monitor shows no signal. The card does not get hot but the two LEDs start to glow red immediately both are between the first and second fan, one under the inscription HerculeZ and the other low under the fans. It turns out that the computer does not see the graphics card, it is not in Cpu-z and the device manager, I wanted to install drivers from the card disc but there is a problem that the program does not see that there is a graphics card connected. I tested the card on two computers
1) Gigabyte GA-H81M-S2PV motherboard Cpu i3 4130 Ram samsung 4GB
2) msi Z77A-G43 Cpu i5 2500k Ram samsung 4gb
And i tested another gpu on those components to be sure that everything is fine. I even searched through internet that there is a program nvidia Mods "MATS" to test GPU's memory or other problems.I downloaded this program from someone's channel on youtube and again i tested it on my 1070 and guess what, there is no video, when it is plugged to gpu.Program fail's when i plug video cable to integrated graphic because it does not recognize my card. AND again the program works perfectly fine when i use my other GPU.
Anyone know what can be the issue with this or what can I do to rule out any problems.
