Input signal out of range?
18 Sep 2011
Newton Aycliffe
Hello guys i have just rebuilt my computer after it was suspected to be overheating, ive added new thermal paste and some fans etc, its nothing special, just something i use at my grans for about 6 hours once a month, so its specs are rock bottom...
Anyway i came to use it the other night and it decided to cut out every 10 minutes or so, ive built computers at school etc, however i have somewhat niglected this computer with it only being used around 1nce a month etc :)
So i took it home where i got out the tool kit, and began work, now looking back it had been running alittle slow, so i bought some new ram (Geil Double channel 512mb twinned) which gave me 1GB (2ce as much as before) So with that slotted in and extra fans and thermal paste in, i decided to boot the machine to which i got a message :
Input signal out of range, recomended settings : 1920x1080 - 60Hz, now my problem being is that this used to be at my grans house, so getting the monitor home is a little trek in the car but not too bad, so i would prefer if there was a kinda "home fix" without retreiving monitors etc :)
The computer itself is a : Fujitsu Siemens Scaleo P (DDR model)
Mobo: Gigabyte GA-8I848PM
GFX card : Gigabyte GV-R92S128T
Any suggestions guys?
Kieran
Assuming you see a bootup screen and then when windows loads up you get this message? If so boot into safe mode or enable VGA mode then set a resolution that works, hold CTRL or F8 down before the Windows splash screen loads to get this menu.
