I installed my new 2900xt on Friday and was initially quite pleased with it. However, after a marathon 6+ hour gaming session on Saturday, I started to have some problems. I had a couple of bsod`s and once or twice the computer froze and I had to reboot. The only part I changed was the GPU and this has never happened before so the finger of suspicion pointed firmly at the new card. I had a feeling it was something to do with overheating so after work today i started to investigate. I`m only using 2x6 pin for power so i couldnt use Ati overdrive and got Ati tools instead. I set it up to monitor GPU temp and fan speed and was amazed to find it was idling at about 80 degrees and the fan was only spinning at 25%. I clicked on "Scan for Artifacts" just to see what it did and the temperature took off like a sodding space rocket. It went up to 96 degrees in about 15 seconds and was rapidly climbing and the fan never spun up any faster. I nearly NO SWEARING me pants. I bottled out at 99 degrees and climbing and turned it off. I played with the fan speed settings, turning it up to 100% at which point it sounded as though my PC was going to take off and the temp slowly dropped to 70 odd. I`ve got it at 75 % now and its idling at 73 degrees. I know these cards are supposed to run hot, but surely this isnt normal? I was pleased with how quiet the card was up until i saw the temps, i`d rather have a noisy and cool card than one i could cook my breakfast on. Anyone else having trouble with these cards?
, but with the fan at 25% idle was around 55 degrees.
, cant afford the new case with the 250mm fan aswell
