** INSOMNIA i54 CRAZY WEEKEND DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
In celebration of the long Easter/Insomnia lan party weekend as always OcUK has some great deals lined up for the event which end Tuesday 9am or when stock sells out, whichever comes first.
So check out the deals:
Asus Radeon R9 290X ROG Matrix Platinum 4096MB GDDR5 PCI-Express Graphics Card (MATRIX-R9290X-P-4GD5) @ £299.99 inc VAT
The ASUS Republic of Gamers (ROG) Matrix R9 290X is a new graphics card that squeeze breathtaking performance from the latest R9 290X graphics-processing unit (GPU).
ROG Matrix R9 290X has been built on the renowned and highly-trusted ROG Matrix legacy as the coolest, quietest and most-readily-overclocked graphics cards available. DirectCU II cooling and CoolTech fan technologies combine with the brand-new Memory Defroster feature to create the perfect balance between spectacular power and out-of-the-box simplicity - all dressed up in the seductive ROG wardrobe.
With support for next-generation 4K/UHD (ultra-high-definition) gaming resolutions of up to 4096 x 2160 pixels, the Matrix R9 290X delivers an incredible gaming experience today and far into the future.
It benefits from hand-chosen cores to deliver clock speeds that are streets ahead. Respectively, the cards speeds along at 1050MHz and 1072MHz (boosted) - that's an incredible 50MHz and 144MHz faster than reference designs.
For serious games-players this means a significant performance boost of up to 13% for super-smooth frame rates that refuse to stutter. With up to 4GB of high-speed DDR5 video memory on board the Matrix R9 290X enables gamers to enjoy very high resolutions and detail levels.
This new ROG Matrix series card is brimming with advanced and exclusive hardware and software features designed to make overclocking as simple and safe as possible.
Memory Defroster is a brand-new feature that's designed to excite extreme overclockers. This clever technology quickly defrosts the graphics card's memory during below-zero overclocking to ensure sustained stability. Extreme overclockers will also appreciate the Matrix series' liquid-nitrogen (LN2) jumper switch, as it enables even more overvolting options - allowing the most adventurous users to unleash maximum greater power from their graphics cards.
The ROG Matrix series' Safe Mode allows users to overclock with complete confidence, as a single button push will restore default BIOS settings instantly.
To support stable overclocking, this card is also equipped with exclusive DIGI+ voltage-regulator modules (VRMs) with Super Alloy Power technology. The DIGI+ VRM delivers 14-phase power and digital voltage regulation, while Super Alloy Power's Japanese-made 10k black-metallic capacitors, 14 ultra-high-amperage full-molded chokes and extremely-efficient MOSFETs all withstand much greater stress and heat due to the application of specially-formulated materials.
The combination DIGI+ VRM and super-strength Super Alloy Power components means that the Matrix R9 290X is forged for high-load performance and extreme overclocking without annoying whines and buzzes noises - so hardcore overclockers can enjoy plenty of headroom for experimental performance tuning without creating gameplay distractions.
ROG Matrix R9 290X stays ultra-cool at all times, thanks some highly advanced and unique technologies - DirectCU II and CoolTech fan technology.
DirectCU is an innovative thermal technology that's exclusive to ASUS. It puts highly-conductive 10mm copper cooling pipes in direct contact with a card's GPU, so heat is dissipated quickly and with extreme efficiency. As well, the new ROG Matrix series introduces a new heat-sink that's finished in a stunning matt black, so the cards look as great as they're kept cool.
This card also features CoolTech fan technology. The CoolTech fan employs a hybrid blade and bearing design, with inner radial blower and outer flower-type blades to provide multi-directional airflow that accelerates heat removal to ensure high-end graphics performance that's highly stable. The fan's ramp is carefully tuned to ensure minimal noise.
For a final dash of style that's loaded with substance, ROG Matrix even features a gorgeous color-coded LED: this shines brightly and changes shade to reflect the GPU's load level, providing a useful visual guide for both casual and hardcore gamers.
The new ROG Matrix card includes GPU Tweak, an easy-to-use utility that gives users intuitive control over GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds, so they can overclock easily and with high confidence.
The exclusive ROG edition of GPU Tweak adds detailed GPU load-line calibration and VRM-frequency tuning, allowing incredibly fine control over multiple parameters for maximum overclocking and the potential to break world records.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time - so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Only £299.99 inc VAT - WITH FREE ROG GLADIUS GAMING MOUSE worth £64.99 !!!!
ORDER NOW
Asus Strix Tactic Pro Backlit Gaming Mechanical Keyboard - Red Switch @ £74.99 inc VAT
Strix Tactic Pro is a mechanical gaming keyboard available with MX red keys that are good for 50 million keystrokes. The Tactic Pro has the highest-specification N-Key Rollover (NKRO) technology over USB which ensures that every key press is registered, regardless of how many keys are held down at once. When it needs to behave like a traditional keyboard, the 6-Key Rollover (6KRO) switch flicks its mode instantly. It’s got a total of 21 macro keys; between the 13 dedicated keys, plus, F1-F8 can be additionally reassigned, while the on-the-fly macro-recording key allows actions and keystroke sequences to be captured without interrupting gameplay. The keyboard can be modified with its software or left to use the hardware PnP modes.
Features:
- Full mechanical key switches with lifespan of up to 50 million keystrokes
- N-Key Rollover (NKRO) over USB ensures every action with precision
- 21 easy-to-reach macro keys actuate ultra-fast combo commands
- On-the-fly macro recording simplifies any long and complex series of commands
- Dual modes: driver-free mode brings your favorite profile on-the-go and software mode provides easy adjustments on the driver's interface
Specification:
- Red Cherry MX Switches.
Was [£99.95] Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Asus Strix Claw Gaming Mouse @ £29.99 inc VAT
Strix Claw is an optical gaming mouse with up to 5000 DPI, adjustable in increments as low as 50 DPI. There’s even a DPI clutch button that lets serious snipers reduce the DPI instantly for super-accurate aiming. An LED indicator shows the current DPI status. The Strix Claw packs high-quality Japanese-made Omron® D2F-01F switches for smoother click-action, keeping those pinkies happy, and inside it’s a clever mouse, packing 64KB of memory so it can remember software customizations.
Features:
- 5000 DPI high-precision, gaming-tuned optical sensor
- True 1:1 tracking and angle-snap-free capability
- Instant DPI switches with four DPI stages and additional DPI clutch
- Three independently programmable buttons
- Right-handed ergonomics
- Japanese-made Omron D2F-01F switches
- Angled braided-fiber cable
- Software and plug-and-play hardware modes
Contents:
- Strix Claw optical gaming mouse
- Quick-start guide
- Driver installation CD
Specifications:
- Sensor: PMW3310DH-AWQT
- Resolution: Native 5000 dpi
- Switches: Japan-made Omron D2F-01F
- Frames per second: 6500 fps
- Inches per second: 130 ips
- Counts per inch: MAX. 5000cpi
- Maximum acceleration: 30g
- Lift distance: TYP. 3mm
- Maximum polling: 1000Hz
- Operating system: Microsoft® Windows® XP / Vista / 7 / 8
- Size: 122.55 x 71.75 x 45.25 (mm)
- Weight: 110g (without cable)
- Cable: 2M with gold-plated USB connector
Was [£39.95] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £95.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£106.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Kingston HyperX 3K SSD 240GB 2.5" SATA 6Gb/s Solid State Drive Insomnia deal Only (SH103S3/240G-insomnia) @ £89.99 inc VAT
Kingston's HyperX 3K SSD</b> features a second-generation SandForce controller that delivers high-speed SATA Rev. 3.0 (6Gb/s) performance for ultra-responsive gaming, multi-tasking and multimedia computing power at an exceptional price. It has advanced wear levelling and DuraClass technology for data integrity protection and ultimate endurance over the life of the drive. Available in bundle kits with all the accessories needed, HyperX 3K SSD is backed by a three-year warranty, free technical support and legendary Kingston reliability.
Stuck with a sluggish, unresponsive system? You need the ultimate computer pitstop!
With a Kingston® Technology SSD upgrade, you can simply change over your regular hard drive and seriously refuel your computer with up to 15x faster performance.
With a Kingston SSDNow you can seriously boost your computer's engine with up to 15x more speed than a standard 7200RPM hard drive. The technical breakthrough that is SSDNow is the cost effective performance upgrade with no moving parts - that's reliable, durable and shock-proof! SSDNow is your very own pit crew, dedicated to improving the performance of your computer.
Opt for the handy DIY kit and replace your existing hard drive with all necessary tools. Follow easy, step-by-step instruction guides for desktops or notebooks and turn your computer into a high powered machine.
95k IOPS
Capacity: 240GB
Controller: SandForce SF-2281
Maximum Read: 555MB/sec
Maximum Write: 510MB/sec
Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
NAND Flash: Multi-Level Cell (MLC)
Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
TRIM Support (Requires Windows 7)
Warranty: 3 Years
Was [£109.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
BenQ XL2730Z 27" FREESYNC 144Hz Gaming Widescreen LED Monitor - Black/Red @ £429.95 inc VAT
**FREESYNC AMD Drivers are launched 19th March**
From years expertise in the development of professional gaming monitors and every close encounter with legendary gamers around the world, we have learned that what defines a truly victorious gaming monitor, or should you say “the best gaming monitor”, really depends on the performance-driven features that make the critical difference between victory and defeat. Gaming is in the details that matter. This is why our engineers and designers strive to perfect every detail that may ultimately contribute to the triumph of the game.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
It is absolutely vital that the XL2730Z give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5W”, 22”W, 23”W, 23.6”W, 24”W and 27”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2730Z is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2730Z’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20°, and swivels left and right to a wide range of angles. Every XL2730Z can be your personal XL2730Z.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
The Auto Game Mode enables the XL2730Z to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2730Z allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2730Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by AMD FREESYNC™ technology
Specification:-
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x Dual Link DVI, 1x HDMI 2.0, 1x HDMI 1.4, 1x DisplayPort 1.20 (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Dimensions (HxWxD mm): 557.4x663.7x226.0
- Weight: 8kg
- Height adjust stand with pivot, swivel and tilt
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2730z/specification/#skip
- Warranty: 2yr
Was [£499.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
BenQ XL2420G 24" G-Sync 144Hz 1ms Gaming Widescreen LED Monitor - Black @ £419.99 inc VAT
Built for competitive FPS game play, the XL2420G takes the explosive thrills of fast-paced gaming to a 24' screen. The stunning monitor is equipped with the latest Motion Blur Reduction. NVIDIA's latest G-SYNC revolution requires monitor manufacturers to replace their scalar with a G-SYNC, trading in the freedom to scale settings like input frame, colour hue, intensity and contrast for pure speed and smoothness of the game.
With the best efforts of our R&D champions, we've found a way to keep your options open with the world's first hybrid engine design. So you are in control of matching your choice of gameplay. For those in favor of perfect motion gaming that can be tailored to match their gameplay preferences, the Classic Mode offers a wide array of customizable settings, from Motion Blur Reduction to Gaming Refresh Rate Optimization Management (GROM), Black eQualizer, Display Pilot, Smart Scaling, S Switch, and Game Mode Loader. The mode also features BenQ's exclusive Gaming-comfort Flicker-free Technology and Low Blue Light modes to help protect your eyes from computer-related discomfort. In essence, it's a total package solution for agile performance, precise control, intuitive user experience and eye comfort.
What's more, with this mode, you can be sure to get the best gaming experience for games unsupported by the G-SYNC Mode. By synchronizing the XL2420G's display refresh rates to the GPU in a GeForce GTX-powered PC, the G-SYNC Mode enables images to appear instantly the moment they are rendered. The low latency effectively eliminates screen tearing, and minimizes display stutter and input lag - frame rate artifacts commonly seen in high-motion gaming. Ultra Low Motion Blur (ULMB) is also at your disposal to smooth the way for a near-zero motion blur performance. Ultimately, with NVIDIA's G-SYNC technology, an unprecedented buttery smooth, ultra-responsive gameplay to victory is all you'll get.
BenQ's new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
Features:
The Hybrid Engine G-SYNCT Gaming Monitor - NVIDIA's latest G-SYNC revolution requires monitor manufacturers to replace their scalar with a G-SYNC, trading in the freedom to scale settings like input frame, color hue, intensity and contrast for pure speed and the smoothness of the game. With the best efforts of our R&D champions, we've found a way to keep your options open with the world's first hybrid engine design. So you are always in control of your desired gameplay.
BenQ Proprietary Classic Mode Tap into Unlimited Potentials of Total Maneuverability - For those in favor of perfect motion gaming that can be tailored to match their gameplay preferences, the Classic Mode offers a wide array of customizable settings, from Motion Blur Reduction to Gaming Refresh Rate Optimization Management (GROM), Black eQualizer, Display Pilot, Smart Scaling, S Switch, and Game Mode Loader. The mode also features BenQ's exclusive Gaming-comfort Flicker-free Technology and Low Blue Light modes to help protect your eyes from computer-related discomfort. In essence, it's a total package solution for agile performance, precise control, intuitive user experience and eye comfort. What's more, with this mode, you can be sure to get the best gaming experience for games unsupported by the G-SYNC Mode.
NVIDIA-Powered G-SYNCT Mode Sway Your Enemies with Game-changing Smoothness - By synchronizing the XL2420G's display refresh rates to the GPU in a GeForce GTX-powered PC, the G-SYNC Mode enables images to appear instantly the moment they are rendered. The low latency effectively eliminates screen tearing, and minimizes display stutter and input lag - frame rate artifacts commonly seen in high-motion gaming. Ultra Low Motion Blur (ULMB) is also at your disposal to smooth the way for a near-zero motion blur performance. Ultimately, with NVIDIA's G-SYNC technology, an unprecedented buttery smooth, ultra-responsive gameplay to victory is all you'll get.
Motion Blur Reduction for Extra Clarity Throughout the Game - BenQ's new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
Low Blue Light as Eye Safety Precautionary Measure - Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ's new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Gaming-comfort Flicker-free Technology - Developed in collaboration with pro gamers, the XL2420G has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Gaming Refresh rate Optimization Management - As the world's leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management, which aims to bring users the incomparable gaming performance. With the gamer-driven Gaming Refresh rate Optimization Management that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
The Game Mode Loader Lets You in on the Secret - The secret is out. Download special gaming presets used by the professional players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from professional gamers will be released in the future so you can always stay on top of your game.
Display Pilot for On-Screen Display Navigation - The new Display Pilot software provides the platform for users to make on-screen display adjustments and the convenience of direct access to the Game Mode Loader site for downloading and installing the preset display settings of their favorite game or professional gamer's screen instantly.
Specially Designed S Switch for Swift Control and Navigation - The XL2420G comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
Customize Your Individual Viewing Preference - The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes , from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) to 24"W (16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast 1ms GTG Response Time - Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
Play like a Pro With the Exclusive FPS Mode - Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
Intuitive UI for Easy Navigation - Conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
Ultra-Flexible Height Adjustment Stand and Others - The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
A Technological Work of Beauty - The XL2420G is not only designed with durability, sturdiness and functionality in mind, the stylish look also earned itself several international design awards: the reddot design award 2011, the G-Mark Good Design Award 2011, and iF product design award 2012.
Windows© 8/8.1 compatible - The XL2420G has passed Windows 8/8.1 certification and are fully compatible with both color systems. Plug in the XL2420G to your computer, and Windows 8/8.1 will recognize it instantly, making setup and connection effortless.
ecoFACTS Label - ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products. Mercury-free LED-backlit display Eco-friendly ink printing in packaging box BFR/PVC-free casing plastics
Specification:-
- NVIDIA G-Sync Technology
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 100.000.000:1
- Contrast Ratio Typical: 1000:1
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port / DisplayPort)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: DisplayPort, DVI & 2x HDMI
- VESA: 100x100mm
- Dimensions (with stand): 571 x 516 x 149 (WxHxD)
- Dimensions (without stand): 571 x 337 x 62 (WxHxD)
- Warranty: 2yr (On-Site with BenQ - 0207 216 0039)
Was [£429.95] Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
BenQ RL2755HM 27" Widescreen LED Monitor - Black/Red @ £199.99 inc VAT
The RL2755HM is designed to give you the most fluid console gaming experience. The 27”W professional console gaming monitor offers every motion with no latency, low input lag and the best visibility with the latest features: 1ms GTG response time, dual HDMI, the Black eQualizer and image quality supported by BenQ’s world-leading color expertise. So you can stay fiercely competitive while enjoying total gaming satisfaction.
Built to set the benchmark for Console gaming monitors, the RL2755HM is a true testament to the belief that 'gaming is in the details'. Each and every feature has been meticulously thought out and created together with pro gamers, to provide Console gamers with vital visibility and command to take their performance to new heights.
Control your gaming destiny and don’t leave it in the hands of slow display. Blistering fast response time of 1ms GTG means virtually unnoticeable input lag for action-oriented console games. All fast-moving action and dramatic transitions will be rendered smoothly without smearing or ghosting. In turn, every your movement can be faster on the gaming monitor than on a traditional television.
Every detail about the RL2755HM screams out perfection for console gaming – even when it comes to storage for your gaming gear. The next-generation angular, compact base stand has been enhanced with slip-resistant rubber finish on the inner side to effectively grip your controller, so you can easily tuck it away and out of the way after each game. Even though the RL2755HM is built with speakers for outstanding audio output, a retractable headphone hook has also been installed at the side of the monitor display for you to keep your favorite headphones within arm’s reach. Last but not least, you can keep your desk space tidy and the cables tangle-free using the glossy red cord organizer behind the neck of the monitor. With the RL2755HM, we hope to complete your console gaming experience with quality and design unmatched by any other.
Equipped with two HDMI ports, the RL2755HM allows you to connect your game console and another HDMI device at the same time. So there’s no need to frequently plug and change your connection. Having two HDMI ports available also means you can play head-to-head with another player using the same screen, as well as mirror your gameplay to a larger display when there’s a larger audience without risking input latency, especially for time-sensitive console game genres.
Gaming is in the details. Every feature and function of the RL2755HM is designed and tested by professional gamers and BenQ color experts to provide you with vital visibility and command for console gaming. The monitor is also meticulously developed to bring out every color, shade and tone with optimized clarity and precision. This is all to help you thrive and achieve peak performance.
It is absolutely vital that the RL2755HM give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
Poor visibility in dark scenes can cost even the most skillful gamers their game. To give you unprecedented level of control and visibility for console gaming, the RL2755HM is built with the Black eQualizer color engine technology to brighten dark scenes without over-exposing the bright areas. This helps preserve vital details, enabling you to spot your enemies easily in critical combat and react quickly in any situation.
Absolute focus on characters is the key to master every fighting game. To optimize the gamers' chance of winning, BenQ invited fighting game legend, Justin "JWong" Wong of Evil Geniuses, to co-design the Fighting Mode. Through this feature, gamers can access specific color calibration settings that help them highlight the characters in combat, giving them the boost they need to improve their gameplay and destroy their opponents.
Developed in collaboration with pro gamers, the RL2755HM has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Specification:-
- Screen Size: 27"W, TN LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276mm
- Brightness: 250cd/m2
- Contrast Ratio: 1000:1
- DCR: 12M:1
- Response Time: 1 ms GTG
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Terminals: D-sub / DVI-D / HDMI x2 / Headphone jack / Line in
- TN LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Black eQualizer
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 2W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- K Locker: Yes
Was [£229.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
BenQ XL2430T 24" TRUE 144Hz Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £289.99 inc VAT
As the world’s leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management (GROM), which aims to bring users the incomparable gaming performance. With the gamer-driven GROM that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
It is absolutely vital that the XL2430T give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20v, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5”, 22”W, 23”W and 24”W.
The Auto Game Mode enables the XL2430T to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2430T allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
Developed in collaboration with pro gamers, the XL2430T has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Specification:-
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Aspect Ratio: 16:9
- Resolution (max.): 1920 × 1080
- Display Area(mm): 531 x 298
- Pixel Pitch (mm): 0.276
- Brightness (typ.): 350 cd/m
- Contrast (typ.): 1000:1
- DCR (typ.): (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. 1ms (GTG)
- Display Colors: 16.7 million
- Color Gamut: 72% NTSC
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- Power Supply: (90~264 AC) Built-in
- Power Consumption: (Base on Energy star ): 24W
- (Power saving mode): 0.5W
- Kensington Lock: Yes
- Dimensions: (HxWxD mm) 516 x 571 x 149
- Net Weight (kg): 6.1
- Motion Blur Reduction: Yes
- Low Blue Light: Yes (10 levels)
- Black eQualizer: Yes
- Game Mode Loader: Yes
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 24"W
- Smart Scaling: Yes
- FPS / RTS Mode: Yes / Yes
- Flicker-free Technology: Yes
- Display Pilot: Yes
- Senseye: Senseye 3
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment: Stand (mm) 130(adjustable down to the base)
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2430t/specification/#skip
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Acer Predator XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £299.99 inc VAT
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:
- G-Sync Technology
- 3D Vision Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr (On-Site with Acer - 0371 760 1000)
Was [£389.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Acer CB290HU 29" Super Widescreen LED Monitor - Black @ £319.99 inc VAT
The Acer CB0 Series monitors provide an outstanding visual experience via high resolution and wide viewing angles1. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Specification:-
- Height adjust stand with pivot and swivel
- IPS Panel
- 178/178 Viewing Angles
- Viewable Image Size: 29" (21:9)
- Brightness (typical): 300 cd/m2
- Contrast Ratio: 100000000:1
- Response Time: 6ms
- Optimum Resolution: 2560 x 1080 @ 60Hz
- Colors Supported: 16.7 Million
- Inputs: RGB D-Sub, DVI-D, HDMI & DisplayPort
- Built-in Stereo Speakers: Yes / 6W
- ENERGY STAR ? Compliant: Yes
- EPEAT Rated: Yes
- Warranty: 3yr (On-Site with Acer - 0371 760 1000)
Only £319.99 inc VAT.
ORDER NOW
Acer Predator XG270HUomidpx 27" FREESYNC TN 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HG0EE.001) @ £429.95 inc VAT
The first FreeSync monitor available for pre-order, based on a very unique high performance TN panel designed for gaming with a 2560x1440 resolution, 144Hz, 1ms, Zeroframe and FreeSync support.
Features:-
Specification:-
- Panel: TN
- Connectivity: 1x DVI-D, 1x HDMI, 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Speakers: 2x2W Stereo
ORDER NOW
SuperFlower Leadex Gold 1600W Fully Modular "80 Plus Gold" Power Supply - Black @ £179.99 inc VAT
SuperFlower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Gold to their range, offering up to 90% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Gold rated PSU's on the market.
The SuperFlower Leadex Gold 1600W Power Supply features a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features:
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 87% 90% 87% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications:
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 90% (115V), 80 Plus Gold certificate
- Active PFC
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1,599.6 W / 133.3 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HG
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was [£224.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1600W Fully Modular "80 Plus Platinum" Power Supply - Black @ £199.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Platinum to their range, offering up to 92% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Platinum rated PSU's on the market.
All Leadex Platinum Power Supplies feature a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features:
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
Specifications:
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- -12V: 6 W / 0.5 A
- Partcode: SF-1600F14HP
Connectors:
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was [£254.99] Inc. VAT
ORDER NOW
SuperFlower Leadex Titanium 1600W Fully Modular "80 Plus Titanium" Power Supply - Black @ £229.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed the Leadex Titanium range, with full 80 Plus Titanium Certification, offering up to 94% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest Titanium rated PSU's on the market.
All Leadex Titanium Power Supplies feature a fully modular design, 140mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Titanium series are an uncompromising masterclass of design and functionality and should be the first choice for any gaming system that needs one of the most efficient power supplies on the market!
Features:
- 80 PLUS ® Titanium Certified, 92% 94% 90% Efficiency At 20% 50% 100% Rated Load
Specifications:
- Efficiency: max. 94% (115V), 80 Plus Titanium certificate
- Active PFC
- 3.3V: 24 A
- + 5V: 24 A
- -12V: 6 W / 0.5 A
- Partcode: SF-1600F14HT
Connectors:
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-Pin-PCIe
- 14 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Only £229.99 inc VAT.
ORDER NOW
We hope to see you at the show and remember these deals end first thing Tuesday or when stock sells out. Have a great Easter Break! :)
Guys, i'm trying to order the kingston ssd but every time i try to click 'go to checkout' the website logs me out :(
Seem to remember something similar a while ago, make sure you're not logged in on another machine or tab on your browser, if it's not that clear your cookies and try again.
Nope not logged in anywhere else and have just tried that but the same issue occurs :( tried it on both IE and Chrome - I'll post in customer services
