Hey,
Just got a new laptop; the Dell Inspiron 1520.. and I'm having problems with the integrated webcam! I'm running XP.
Basically testing initially out of the box the webcam seemed to work. I then installed several bits of software and came to use it the next day and nothing. I'd run the Dell Webcam Center and just see a black screen, no error message, no picture, nothing! The webcam blue led light came on though.
So I tried the usual, uninstalling drivers, reinstalling, tried different newer/older drivers, searched the web for similar problems but with no solution to be found.
Next I decided to format as I had only installed several pieces of software and thought it would be worth the hassle if it fixed the webcam problem. So after a clean install and with all drivers from the 'resource' cd reloaded, bar the webcam center software. The webcam worked!
I thought that was the end of the problem. But then I plugged in a SD memory card to get some photos from it and my laptop automatically installed an SD host controller driver.. The webcam froze; so I tried opening the software again and now all I see is a black screen. No picture at all the same as before. The led light comes on to show its active, but no picture, if viewed using windows it is also blank; I've now tried everything to get it working again but nothing.
So it looks like a driver problem; but I've tried every driver available this includes two creative drivers, microsoft generic driver and dell's driver.. but with no luck! As you can imagine I don't want to have to format again..
Any help would be greatly appreciated,
Thanks.
Spec ref:
T7250 Core 2 @ 2ghz
2gb DDR2
15.4 @ 1440x900
160gb HDD
8600GT 256mb
Windows XP
Thanks.
Spec ref:
T7250 Core 2 @ 2ghz
2gb DDR2
15.4 @ 1440x900
160gb HDD
8600GT 256mb
Windows XP
