Inspiron 1545
1 Aug 2003
Can anyone recommend a suitable neoprene jacket for these?
The 1545 seems to have a slightly unusual screen size at 15.6" and I can't seem to find a jacket that I can be certain will fit it.
Thanks
I'm using a Belkin 17" one with mine, but I don't know if I'd recommend it.
It's the problem with these 15.6" laptops, you need a 17" case for the length but then there ~1" of play in the width. I'd imagine they would not fit at all into a case for a 15.4" laptop.
