Insprion Power Blocks
12 Dec 2006
Can I use a charger from a 9400 on a 640m
I don't have them to hand to check the power inputs current etc.
640m
Power Cord: Included
Voltage Provided: 19.5VDC
Voltage Required: 90-135 VAC / 164-265 VAC
Size: 2.28" x 5.4" x 1.11"
Max Out: 3.34 A
Power Provided:65 Watts
9400
Voltage Required: 90-264 VAC / 164-265 VAC
Max Out: 4.62 A
Power Provided: 90 Watts
The rating is only the maximum output, it will only draw the needed current, so it will work fine, i use a 6amp test psu on all laptops from 3.5 upwards with no problems at all.
Its smaller rated psu on a bigger laptop where you have problems.
