Instability after Overclock whiped.
8 Nov 2011
I'm not really sure where to put this tbh. But anyway, I purchased an overclocked bundle from OCUK just over a year ago and everythings been fine, till I installed windows 7 a week ago. I started getting artifacting in games so, eager to rule out any possibility of hardware, after several hundred reinstall of ATI drivers >< and booting up with onboard graphics.
So i tried booting up with 1 stick of ram.. wouldnt post. Tried the other stick, wouldnt post. Put both back in and ok so it booted, but overclock settings cleared.
Since then no matter what I tried to do interms of bios settings, everything got worse. Screen flickers white now, sometimes it just completely jams up no BSoD. Just freezes. Flash/Silverlight videos will get a green overlay temporarily. The ingame artifacting is about the same if not worse.
Just overal performance went down the pan. :( I have tried with the OCUK Profile in Bios, optimized, and this mornign i woke up to my computer continuly triyng to boot and failing.
I couldnt find anything in my system logs that made it reboot, I can only assume it jammed up.
Just not realllyyy sure whats wrong now :/ Any ideas?
post in the shop forum, down near the bottom of the list,might help if you have the order number as well.
have you loaded the default bios settings ?
Oh woops. System specs.
i3 2.9Ghz, (133*22)
Corsair XMS3 DDR3 1600Mhz (running at 1333 i belive)
Radeon HD 5670 1gig
corsair tx650W
