Instaling W7 64 bit from XP 32 bit,
27 Nov 2007
Manchester
Hi all,
Have a retail W7 HP package and I want to install 64 bit. I tried booting from the 64 bit disk but I get errors about no bootable media, am I missing something?
Cheers.
Are sure you have your DVD drive set as the boot drive in your BIOS/Boot order menu?
You can also check the disc is not faulty by booting from it on a different machine [it won't cause any damage unless you choose to install so this is perfectly safe].
