4 May 2009 at 11:13 #1 rossyl rossyl Soldato Joined 27 Oct 2002 Posts 4,280 Location London Was wondering what the technique was for this. It's an old Compaq machine, unsure if i can boot from USB. Any tips? Thanks
4 May 2009 at 11:17 #2 Theguy Theguy Associate Joined 26 Dec 2006 Posts 1,300 Location Oxon. its going to require quite abit of effort on your part. have alook at the eeepc forums, theres abig section on installing xp from usb. that or could you get your hands on a cd drive just to install, and then take out afters?
4 May 2009 at 12:07 #3 eXor eXor Soldato Joined 13 Nov 2002 Posts 3,589 I used to install Win2K Pro from hard disk. Not sure if it is possible with XP? IIRC : Format the win partition as fat32 and make it bootable. Copy CD contents across. Boot. Run ' \i386\winnt.exe ' Try slapping Windows 7 on there!
4 May 2009 at 12:23 #4 J.B J.B Soldato Joined 16 Aug 2006 Posts 5,924 It is possible but for the effort Id consider buy a £10 optical drive.
4 May 2009 at 13:40 #5 chrisxuk chrisxuk Soldato Joined 24 Nov 2008 Posts 3,745 Location ctf_2Fort So you wouldn't need to get a DVD Drive, just a CD drive?
4 May 2009 at 14:01 #6 willhub willhub Caporegime Joined 3 Jan 2006 Posts 25,335 Location Chadderton, Oldham I'd just get a drive and some decent cd's. Wish it was like Windows 7, extract ISO/CD/DVD contents to USB stick, boot, select USB stick, done
4 May 2009 at 16:15 #7 J.B J.B Soldato Joined 16 Aug 2006 Posts 5,924 chrisxuk said: So you wouldn't need to get a DVD Drive, just a CD drive? Click to expand... XP is a CD. Pretty sure Vista and 7 are too big so have to go on a DVD
5 May 2009 at 12:04 #8 rossyl rossyl Soldato OP Joined 27 Oct 2002 Posts 4,280 Location London Here's what i'm thinking. 1. Try and make it boot from USB. If so, stick the whole XP CD on the USB stick. If this does not work. 2. If I can log on to the PC (this may be an issue) create a partition. Copy the XP CD to this partition from a USD hard drive. If either of those do not work...well then I've no clue.
5 May 2009 at 12:13 #9 bledd bledd Don Joined 21 Oct 2002 Posts 46,879 Location Parts Unknown use this. http://www.msfn.org/board/index.php?showtopic=120444 use the Hp tool (included) to format your usb stick and make it bootable read instructions carefully
